Blocking a circle shape
sbanquer
Postby sbanquer » 25 Aug 2016, 22:39
Have a row of movers all doing circles on fader1. Programmed half to go to drummer position and change to white on second fader and made high priority. When fader 1 is up fader 2 turns white and changes position but continues circles. Is there something else besides having a higher priority I'm supposed to do for fader 2?
sbanquer
Re: Blocking a circle shape
Postby sbanquer » 25 Aug 2016, 22:47
Found it. Go to (shapes effects) (shape generator) (create) (pan tilt) then find (block all shapes). I didn't delete in case anyone else had trouble with this
yyy898
Postby yyy898 » 27 Aug 2016, 08:21
sbanquer wrote:Found it. Go to (shapes effects) (shape generator) (create) (pan tilt) then find (block all shapes). I didn't delete in case anyone else had trouble with this
this will also block your dimmer / colour / ... shapes.
If you only want to block a pan/tilt shape you can choose the block pan/tilt shape which doesn't affect your dimmer / colour / ... shapes
Users browsing this forum: No registered users and 12 guests
