Hello guys,
Something very strange happened in my 2 last shows.
I have in my showfile a lot of cuelists, i use them mainly as cue stacks for effects of dimmer, colors and movements. all of them using the Autoload function.
I updated my Titan Mobile to V10 15 days ago, the showfile i use was created in V9 and used almost every week for about one year. never had this issue i will report before.
For some random reason, some cues get stuck after some time playing with the cuelists. I tried to reproduce the error, without success. In my last 2 shows, 2 different cues from different cuelists got stuck. all of them , dimmer shapes , loaded via the Autoload function. Using the Release function did not solved the issue. even hitting the Release All key had no effect, the dimmer shape continued to run , no matter what. i had to shutdown the Titan software and load it again to get rid of the stuck cue.
Can someone tell me if this is a know issue or something?
Right now im going to downgrade my Titan Mobile to V9, and play safe until i can find a confirmed solution for this.
Regards,
Erick Krau
Cues loaded via Autoload getting stuck in V10
Re: Cues loaded via Autoload getting stuck in V10
I have experienced this same issue since loading V10.0 last weekend. Some of my cuelists containing autoload chases work fine, and others have the stuck chase syndrome. This is only one of the issues I have been experiencing, and even after re-installing V10.0 twice, the problems persist. Unfortunately, I am looking to go back to V9.1 now.
I have found a way to reproduce your bug with chases getting stuck on and have entered it in our bug tracking system. I have seen this when there is a fade time on the cue and the Go button is pressed before the previous cue has completed fading however even then it does not happen every time.
