Programming a show and using cue list. After creating a cue list and then going back to normal recording of play back i am unable to set a legend on a normal playback as it says "the selected softkey does not support picture legends, Please select the legend softkey"
Once i restart the Titan software i am able to set legend
Anybody else experiencing this?
Console is a Tiger Touch Pro
Cue list Bug in V10
grahamrobertslx
Re: Cue list Bug in V10
Confirmed.
The way I was able to reproduce was to attempt to set a picture legend on a cue in a cuelist. This would result in the warning prompt. Then subsequent attempts to set a picture legend for single cue playbacks results in the same warning prompt.
The warning prompt text is also wrong.
Note that when I tested you can resolve by setting a text legend first.
#65479
#65479
grahamrobertslx
Cool, at least i know its an issue and not just me been stupid.
One problem solved
Cheers Nic
One problem solved
Cheers Nic
Users browsing this forum: No registered users and 83 guests
