Can i use more cue-lists on the same time with the "go" button?
Example:
Fader 1: cuelist: dimming wash movingheads
Fader 2: cuelist: dimming profile movingheads
Can i get both cues under the "GO" butten at the same time?
Or does i have to make a new cuelist under fader 3: dimming wash and profile movingheads?
I hope to you can help me
More than 1 Cue with "go" button
Light-Tech
Re: More than 1 Cue with "go" button
Light-Tech wrote:Hello,
Example:
no you can't,
what you can do is write a macro which presses both lists go button (by default the grey flash key) and record that to a free button which you want to use as a go
The simplest option would be to record an empty cue list with one cue, open up the new list and add autoloads for both of the other lists, then select each autoload and set the type (softkey B) to Press Go On Target.
Users browsing this forum: Google [Bot] and 13 guests
