Quartz RDM setup with Artistic license Data lynx/ lumen radio RDM
yanlingg13
Postby yanlingg13 » 27 Jul 2016, 05:10
Hi All!
I have issues using RDM on my quartz console.. Here's the situation:
I wanted to use RDM with Showline Epar 180 which is RDM compatible - there isn't anything that I can set on the fixture to enable rdm (its alr enabled with a RDM ID)
Firstly, I connect directly from my console physical dmx port to the fixture with a 5 core DMX cable and select full discovery on RDM (nothing came up)
Then I switch to Lumen radio wireless transmitter and receiver both with RDM, tried physical dmx port to transmitter and dmx from receiver to fixture (no luck either). Thinking that perhaps Ethernet might work, so I switch to Ethernet cable to transmitter, dmx from receiver to fixture - still nothing on rdm.
Lastly, I use Artistic license data lynx which is a artnet to dmx node with RDM. still.. nothing came up.
I wonder if any of the steps that I did was wrong?
Please help! :(
Yanling
