V10-Capture Bug? Colors on generics
Beast
Postby Beast » 17 Jul 2016, 16:18
Hi.
Since we're going to be using a lot of generics (par64, pinspots....old school stuff :wink: ) at a coming event, i thought i would give it a shot in the new Capture visualizer. Here i discovered that when setting a color e.g R 100, G 50, B 0, and saving the show, when reopening the show, the parameters saved at 0 , B, in this instance, doesn't visualize anymore. I can adjust , but it doesn't show. Tested by setting RGB at zero(no light with dim at 100), saving-reopening-setting R 100- still no light. Tried making different shows, and the fault seems consistent. Is this intentional, a bug or me??
Sincerely
Beast DK
Re: V10-Capture Bug? Colors on generics
Postby niclights » 17 Jul 2016, 18:37
Confirmed - adjusted dimmer properties act as limits when loaded.
Beast
Postby Beast » 17 Jul 2016, 21:11
Thanks for confirming!!!
Beast
Postby Beast » 19 Jul 2016, 06:52
Playing around a little further, i found that if you wipe the visualizer in vis settings, which luckily doesn´t affect positioning of fixtures, i was able to regain visualization control of the dimmer proberties. Still a bug, but a workaround for now.
