Titan V10 can I use the second console outputs?
cuelist
Postby cuelist » 08 Jul 2016, 04:12
Hi guys I'm trying to figure out if I can use a networked console's DMX outputs...for example if I had two Tiger Touch, could I use 8 DMX outputs, 4 from the master and 4 from the slave/backup?
Thank you
Re: Titan V10 can I use the second console outputs?
Postby niclights » 08 Jul 2016, 10:08
As far as I know the outputs are only from the master console. However, you could use Art-net and an Art-net to DMX converter to get 8 outputs.
Olie
Site Admin
Postby Olie » 08 Jul 2016, 14:28
Only the master console or a TNP can directly output DMX. However it is really easy to assign another consoles outputs to sACN universes. This will achieve the same result and allow those DMX outputs to be used. Just go into system and select "Merge DMX Settings".
