winamp Timecode problems
bassoccello
Postby bassoccello » 01 Jul 2016, 20:31
Hello there, I have a problem with my TitanOne:
I'm using Timecode (from Winamp) to fire cues from cuelists, all work fine and cool, but seems that cues restart randomly. For example: I press play from winamp, the show starts and seems ok: the cues start perfectly in time, just as I setup them in timecode. But the problem is with the single cue: when the cue starts it seems like Winamp sends a Go message then another Go and another and so on, randomly. When next cue starts, the same bug appears.
The Cue lists and the cues in cuelists work properly in timecode, but each cue has this problem.
Can someone help me please?
Re: winamp Timecode problems
Postby Gregory » 01 Jul 2016, 20:36
Is the Link for all the cues set to Wait For Go? If any are set to After Previous or With Previous they may fire due to that as well as responding to timecode.
bassoccello
Postby bassoccello » 02 Jul 2016, 11:45
thanks for answer! All cues are set to Wait For Go... :(
Postby Gregory » 02 Jul 2016, 16:31
When you talk about a single cue, is this part of a cue list or a separate cue? Double check that there aren't stray timecode times as these might cause the software to jump forwards or backwards through the list. Also if you have multiple timecode cue lists, check those aren't also triggering.
