Titan V10 bug or id10T error?
Ockert
Postby Ockert » 01 Jul 2016, 19:56
Hi guys!
At last V10 arrived :shock:
I used the shape generator to create shapes like circle, pan saw and tilt saw, works perfect (love the direction option and workspace resizing, wishing for a randomize option in shapes direction)
Saved it onto a fader
Playback options
Effects
Setted it to overlay, shape size to fixed and shape speed to on fader
But the shape size increased as I raised the fader
Any comments would be much appreciated
Re: Titan V10 bug or id10T error?
Postby niclights » 01 Jul 2016, 20:12
I can't repeat this. All appears to be working correctly for me. Check that you don't have it set to mode 2 as well.
The last option in directions is random (crossed over lines). This will generate a random shape fixture order each time you press it.
Ockert
Postby Ockert » 01 Jul 2016, 21:34
Thanks Nic!
Running mode 1
Big change between size on fader and fixed but still not working correctly
Mode 0 looks like its working!
Thanks man! Appreciate the trouble!
Postby niclights » 01 Jul 2016, 22:14
Unfortunately it does look like there is an issue with mode 1.
