Hello Guys!
Soon i will need to program a show in timecode, via Winamp using a Titan Mobile. I already did it some times using a Tiger Touch with the Winamp supplied with it, but not yet in my Titan Mobile.
My question is: there is a specific version of Winamp i need to download and use in my Titan Mobile? or can i download and use the latest version available in this link? http://forums.winamp.com/showthread.php ... 9#download (Winamp 5.666 latest version right now)
If the version from this link is ok , there is anything else i need to install/do ? i saw in the Avolites site a Winamp plugin to download (AvolitesWinampPluginSetupV2.exe) , i need it too or not?
(FYI: Im using Windows 10 on my Titan Mobile setup.)
Best Regards,
Erick Krau
Winamp version for Titan Mobile
Re: Winamp version for Titan Mobile
Receiving Timecode from Winamp should work regardless of the version of Winamp. You will only require the Avolites Winamp Plugin if you want to use the personality to control Winamp (e.g. Play/Pause, track select).
Ok, Thank you Gregory!
Regards,
Erick Krau
Regards,
Erick Krau
