change time of multiple playbacks at once?
Is there a way to change the fade in of several playback cues at the same time. I would think it should be possible by selecting "edit times" and dragging a finger across a few cues and then changing the time, but that doesn't work. Is there a way to do this?
Re: change time of multiple playbacks at once?
No you can't currently range select playbacks in the Edit Times menu. Note that you can switch between playbacks while in the Edit Times menu so you can type the time, select another playback and type the next time. You can also use times in the programmer, so put the cue time in the programmer (e.g. fade or delay time) and then merge that into as many cues as required (you can also Latch the Record menu so that all you need to do is double tap on each cue in turn).
