Group buttons quit selecting
In the middle of programming the fixture group buttons quit responding. Could not select, or make new groups? Opened new show and they worked as intended. Any thoughts?
Re: Group buttons quit selecting
Is it possible that the selected key profile had been changed? The current key profile should be shown in the prompt next to the softkeys and you can select or edit the current key profile by holding down the Avo key and selecting softkeys F or G. The reason I suggest this is that it is possible to set the group button action to disabled in a key profile and the built in Run key profile will be set like this.
Found that it is just slow reacting. Not sure this laptop is spec. Windows 10
Intel Celeron ns2830@ 2.16ghz
Any thoughts?
Any thoughts?
The recommended specification is an Intel i5 processor and even for similar clock speeds the performance of an i5 maybe several times that of a Celeron. There maybe also other factors such as graphics performance, size and speed of RAM and what other applications are running in the background.
