Fixture overlap
Fixture overlap
After reading some manual I see fixture overlap was removed from chases. Not sure how to proceed. Can I make a cue with overlap then add more cues and make into a chase. Will the overlap carry through to the other cues?
Re: Fixture overlap
I'm not sure what you are reading or why you think that but Fixture Overlap is available in chases. [Edit Times]/<select chase playback>
Re: Fixture overlap
Titan mobile manual p166
Re: Fixture overlap
Cue Overlap is a separate function to Fixture Overlap the former was replaced by the more powerful Link Offset in cue lists the latter is still available for both chases and cue lists.
Re: Fixture overlap
Oh thanks. This is a bit of a learning curve from light jockey
