Bpm Timing with fixed strobes
sdowdesw
Postby sdowdesw » 07 Jun 2016, 18:12
Hi there
I’m new at this forum bit, I’m working titan one system. Can anyone help me I’m trying to see if it is possible to put bpm on a SGM Flasher 1.5 strobe if so How :?: :? :? :?:
Re: Bpm Timing with fixed strobes
Postby niclights » 07 Jun 2016, 18:35
According to the fixture manual the range is 0 to 50 flashes per second which theoretically translates to 0 to 3000 flashes per minute. So you could edit the personality and change the strobe display range to 0 to 3000. I wouldn't rely on this being too accurate though, especially as there are only 256 discreet levels within the range (ie. the actual resolution would have a variance of up to 12 BPM either side of the value set).
sdowdesw
Postby sdowdesw » 07 Jun 2016, 19:57
thanks for that.now can asign bpm1 master to a cue so if the band is at 25 bpm set my strobe to the same ? if so how
thanks
Postby niclights » 07 Jun 2016, 21:01
No. That is not possible, sorry. Speed masters apply to chases and shapes.
sdowdesw
Postby sdowdesw » 07 Jun 2016, 21:40
thanks for all your help
stuart
Stavrosg
Postby Stavrosg » 09 Jun 2016, 21:13
If the band is quite consistent and play on metronome you can set different strobes on the beam palletes. Or just mode 2 like a professional busker
