Coming from an ETC background, I've been trying to figure out how to make an inhibitive sub or playback.
I've tried an Alt Linear Curve on a Playback with Highest priority but that is not the solution.
Any suggestions appreciated.
Jim
Inhibitive sub/ playback
Re: Inhibitive sub/ playback
There is no 'Inhibit' function as such but I would suggest the best solution is a group master assigned to a fader. This should be the same other than the action will be inverted - ie. at full = assocatiated fixture intensities are unaffected / at zero = associated fixture intensities off. Set to scale for proportional control or limit for a hard limit.
Alternatively you could try an empty cue set to mode 3. Raising this will proportionally fade out intensities from all active playbacks with the same or lower priority.
Finally you could look at a custom shape. See the guide I wrote here. Aside from the obvious unsupported customisation the biggest danger with this the need for the custom shapefile to be present when loading the show. This is particularly important if you are moving between consoles or when updating the personality library. I wrote this before group masters were implemented.
Users browsing this forum: Bing [Bot] and 22 guests
