Priority of playbacks?
djsky
Postby djsky » 03 Jun 2016, 18:33
I have a cue on an executor button that changes all the lights to white.
Priority of this cue/button is set to normal.
I have a playback cue (on the playbacks screen) that has a shape slowly changing the colours of some fixtures with a pink/blue effect.
Priority of this cue is set to very high.
However, when I select the normal cue, it still overrides the shape that should be of a higher priority.
Surely this is wrong? Or is it me?
Re: Priority of playbacks?
Postby niclights » 03 Jun 2016, 19:15
I can't reproduce this.
What kind of shape is it? With Key Frame Shapes there is a setting to determine whether they overlay or act as LTP. When set to LTP you would see this behaviour if the shape was the same or lower priority than the white cue. But with the shape as a higher priority it cannot be overridden by the white cue.
Are you sure about the priority settings?
