Pearl Expert Pro Display Setup
Arultech
Postby Arultech » 01 Jun 2016, 15:42
Hi guys,
I am very new to this forum, i am from malaysia, here we have just bought our new Avolite Pearl Expert Pro Console with Touch Wing, I am having a hardtime to connect it with my console, ihave read the manual book as well and sorry to say i cant really solve the issue yet. Can anyone guide me how can I connect this touch wing with my console? Whr can i find this display setup? Thanks in advance... have a great day ahead guys....
Re: Pearl Expert Pro Display Setup
Postby niclights » 01 Jun 2016, 19:12
Avo+Disk / [Display Setup] / [Touch Wing Auto Detect] or [Touch Wing Connected].
Arultech
Postby Arultech » 02 Jun 2016, 03:14
Thanks niclights
Arultech
Postby Arultech » 02 Jun 2016, 12:02
Hi nick.....
Thanks the touch wing is working now but i cant use the wheel on my touch wing... is it there are any set up for me to do? But when i change my attrubute control on console means the console wheel is working....... then if i change it to expert touch the whell on board and touch wing both not working.......
Postby niclights » 02 Jun 2016, 12:15
Unfortunately it is not currently possible to have attribute wheel control on both the wing and the console at the same time.
Arultech
Postby Arultech » 02 Jun 2016, 17:18
So it means i cant use both wheel at same time.... then can i use the wheel only on touch wing? If yes may I know how? Thanks :-)
Postby Gregory » 02 Jun 2016, 17:20
Are any of the buttons/wheels working on the wing? If not, you should check in USB Expert Console to see that the panel appears and the button presses/wheel moves are coming through.
Arultech
Postby Arultech » 02 Jun 2016, 17:23
Currently i can only use the touch screen and none of the button and wheel on the touch wing is working.....
Eli_Feldman
Postby Eli_Feldman » 21 Apr 2017, 04:34
Hello all.
I'm wondering if there is a way to dim the display on the touch wing. I've tried doing it in the windows system settings but that doesn't work. Anyone else run into this issue?
Postby Gregory » 21 Apr 2017, 12:04
Unfortunately there is no back light brightness control for the Expert Touch wing. However you may be able to get a similar effect by adjusting the Color Enhancement settings in the Intel(R) Graphics and Media control panel. You can open Control Panel from the Tools menu by selecting Control Panel followed by the More... option.
tamas70
Postby tamas70 » 26 Jul 2017, 12:09
Hi guys
Touch wing is not properly configured do not work macro buttons, I can not use pixel mapping. How do I properly install your tuoch wing?
Postby Gregory » 26 Jul 2017, 12:34
tamas70 wrote:Hi guys
The macro buttons should work automatically when the wing is connected and you should be able to record playbacks, macros and groups there. Between the master and preset faders there is an LED labelled A, this should be lit up when the wing is connected. You can also check the connection by going to Tools > Control Panel > USB Expert Console and checking that the wing is shown in the Connected Panels list on the left with a green icon.
I'm not sure what you mean about pixel mapping, this should not be dependent on the wing to function. Is the display of the wing working? What software version are you running? Have you checked that the both cables are properly connected to the wing interface board which is above the motherboard connections on the back of the console?
