Hey,
I have a titan one and a location that has artnet and a pearl expert with titan software on it. there are 3 universes, 1&2 for the main stage and 3th universe for the small stage. now is the question, can i plug into artnet (both the titan one and the pearl expert will be on the same network) and use my titan one to send out on universe 3? also is it possible to send out to universe 3 only without the pearl expert? or can a titan one only use the first universe?
I did read somewhere that its possible to combine tables to use more universes... i dont know if this will work for the titan one though...
Sander
Change dmx line from 1 to another
Re: Change dmx line from 1 to another
I tested some things today,
In DMX settings, i changed the "DMX output A Expert DMX" from line 1 to line 3. The dongle is now flashing on Rx instead of Tx witch in my opinion means its not sending out, and nothing works. thing is, that i need to use it on artnet witch i dont have at the moment... so if anyone can tell me if it will work with artnet then that would be great.
I herd some people say in forums that the titan one used to be able to use just one universe but any single one... like you could use line 1 or line 12 if you wanted... and others are saying that that is removes for some reason... that its forced to use only line 1?
it is not possible to change the output to another one, what you can do if its just to test a rig, is to park everything on line one, and repatch line 2 to line 1
