Hello.
Is it possible to assign palettes in the .d4 personality file, and the console to display them when the fixture is loaded ?
I can't make that work like with the old Sapphire 2000 and .R20 files
Palettes in personality files
eugenumail
Re: Palettes in personality files
Yes. There is a 'palettes' section in the Personality Builder. In Titan after selecting a fixture/mode press the [Options] softkey and toggle [Preset Palettes on Workspaces/Presets (Pearl Expert only)].
eugenumail
Thank you. That solved it.
eugenumail
Is it possible to change how some attributes behave, for example when i press "clear" i need the shutter to fall to 0, not to retain the set value.To behave somehow like an HTP channel.
No. There is a legacy function for clear values but it is not currently supported in Titan.
You could look at the Clear option - [Release to Playback values] or perhaps change the attribute ID to 'Dimmer' which will then behave as HTP (note that each attribute must have a unique ID so you can only have one HTP attribute in a personality).
