Prisma recording issue
I have two moving heads recorded in channel mode on three playbacks. First one is intensity and colour, second one is position and on the third I have a prisma effect. I have a release mark including effect on the first playback, but for some reason the prisma effect is stored on the first playback even though it isn't recorded on that playback and the program is cleared. What am I doing wrong?
Re: Prisma recording issue
If the first playback contains prism then you must have recorded it there somehow. You can confirm it's there by viewing the cue. One way to remove it is to select all the prism cells in cue view and then choose [Off] from the softkey menu.
