Hi!
I'm just wondering if the Tiger Touch Fader Wing works with a Quartz console? Or is it only the Titan Mobile Wing that works?
Quarts extra wing
Re: Quarts extra wing
You cannot use it with a Titan One but it's the only limitation ; the TMW works with every Avolites Titan desk (Titan Mobile and above), so no problem using it with a Quartz.
Ok thanks! Than I know. I guess than that it's not possible to see what you have recorded on each playback on the TMW? I like the displays on the TTFW.
Well, yes you can. There's a dedicated workspace window for the TMW where you can legend playbacks and executors. If you use an extra monitor, this actually lines up pretty nice(19" is what i've used) In Titan10 there should be the option of designing your own windows, so phbs even better there?
Sincerely
Beast Dk
Sincerely
Beast Dk
Well I see. Thanks for the tip! Sounds very good so I will keep that on my mind.
I was told on the phone by someone at avolites that the tiger touch wing does NOT work with the Quartz. Only the MOBILE fader wing works.
