Can't find Titan Training Showfile
jackyslim
Postby jackyslim » 14 Mar 2016, 14:47
Hi
I'm currently running through the Titan Training Guide Lvl.2, and in page 2 they said "This training session is based on loading the Titan Training Level 2 showfile BEFORE starting the training." But I can't find such file in the Titan PC Suite I've downloaded, neither on the Internet. Can someone help me find this showfile?
Please help!!!! :cry:
Re: Can't find Titan Training Showfile
Postby Gregory » 14 Mar 2016, 16:27
The exhibition show file which can be found on Capture's website should be fairly similar and there is a Capture presentation file to match. The presentation file can run on a machine without Capture being installed.
jackyslim
Postby jackyslim » 15 Mar 2016, 06:11
Thank you for your reply.
Since I'm using Titan simulator and Avolite Visualizer doing self training at home, and I only get Capture Argo student version, so I can't open up the .c2p file coming with the exhibition show file downloaded from Capture's website. So I want to ask 2 more questions.
Can I use the presentation file to link with Titan simulator the same way as using capture argo?
If not, is there any file that is Avolite Visualizer compatible?
Appreciate
Postby Gregory » 15 Mar 2016, 21:29
Yes, the presentation file can receive DMX in the same way as the full software. It should appear in the available list in DMX Settings however if not you can add either broadcast Art-Net or sACN to each line, judging by the project file it appears to be set up for Art-Net (if it doesn't work with Art-Net universe 0, try starting from 1 instead).
No, I don't believe there is an Avolites Visualiser theatre for that show.
jackyslim
Postby jackyslim » 16 Mar 2016, 04:29
The problem I'm facing is that I can't even find the window for setting universe(Screenshot below), I'm wondering if I've done something wrong, or there is a button to open up the window at somewhere.
Sorry for bothering you :oops:
jackyslim
Postby jackyslim » 16 Mar 2016, 04:31
The image is here
https://goo.gl/jxZmkF
Postby Gregory » 16 Mar 2016, 10:27
The presentation file doesn't have any settings, it is pre-configured. The only settings will be at the Titan side, although these should also be loaded as part of the show file.
If you are not getting a connection, try disabling any network adopters you are not using, ensure Titan is outputting to the required adapted and possibly install and use a loop back adapter if you are running both applications on the same machine.
Users browsing this forum: No registered users and 61 guests
