Copy/merge between showfiles
sajansen
Postby sajansen » 10 Mar 2016, 13:44
Hey, i dont know if its possible but i would like to merge or copy selected fixtures and cue/gobo/etc... from one showfile to another. For example:
Showfile 1:
This showfile has a laser in it with all the patterns hand drawn in the gobo slot for quick pattern selection and some faders for movement/speed/color etc...
Showfile 2:
All the lights from a location i often work.
Now was the idea that when i take my laser with me, that i can use it the same way as when i use it separately. But it would be a day less work if i dont have to recreate all patterns again in showfile 2. So the idea was to just merge showfile 1 into showfile 2 and then repatch the address of the laser and be done.
Thanks,
Sander
Re: Copy/merge between showfiles
Postby niclights » 10 Mar 2016, 15:47
Assuming you're using Titan look at the import function.
sajansen
Postby sajansen » 10 Mar 2016, 17:16
Yes im using titan. Thanks for the tip. i was looking in the wrong place but found it now :)
