I saw this video showing how to control winamp directly within titan using palettes. I tried recording palettes with winamp selected, and attributes dialed to the right ones, but the palettes will not record anything, it would save an empty palettes. I saw that in this video attributes are also empty, as you can see IPCGBESFX are all grey. how did he do it?
https://www.youtube.com/watch?v=BJCe8QeHOSk
many thanks!
patch winamp functions as palettes
Re: patch winamp functions as palettes
Most of Winamp's attributes are in the attribute group 'Special'. To record a palette containing such attributes, either double-click an empty palette button in the Gobos and Beams window, or - in order to record it in another window - press the Palette key, then 'Record Palette' and the target button. Or do the double-tap in Gobos&Beams and then move the palette elsewhere. That guy must have done one of these. And since the palette buttons are so small in the video, the S (for special) is simply not shown
thanks a lot, I tried that it worked. can you also tell me how to save each song as a pallet like he did? also, what do "Load Play", "Load Pause" and "Load Stop" mean, and how do you use them?
thanks again
thanks again
To make a palette for a track, make a palette of the attribute 'Playlist'
Regarding the 'Load xyz' functions: honestly I have no idea. Why don't you just try it?
Hi thanks a lot, I can now play music in titan. i tried the load play, load pause they don't do anything, load stop will act as stop. but i got the functions that i need, thanks again!
