Hi!
I would like to have 4 different playbacks as masters. Two playbacks will be BPM masters to control the shape effect speed - one for LED cans and one for moving heads. And the other two masters will be either Size or Offset - one for LED cans and one for moving heads.
Is this possible? Or any other ideas?
I would like to be able to change everything live in an easy way since I don't know what's coming and the set up time is short.
Thanks!
Shape effect masters Quartz
Re: Shape effect masters Quartz
There are four BPM masters. Control is assigned on a per playback basis. If you want to separate speed control into two sets of fixtures in a single playback I would suggest creating two separate playbacks with speed source as BPM1/BPM2 respectively and then autoload both in a cuelist with a single cue (probably with [Fader Mode Intensity Kill at 0] and [Fire First Cue Enabled]).
Size and Offset masters are currently not possible. There might be some things coming in the next version that help. I wouldn't like to say. But until there are you can assign size to faders.
Users browsing this forum: Bing [Bot] and 27 guests
