How to set a dimmer channel to relay on the D$
LD Andy
Postby LD Andy » 14 Jan 2006, 19:32
I am patching (3) DF-50, and a Mirror Ball for a show, and need to set them to relay curves. How is this done on the D4?
Andy
Olie
Site Admin
Postby Olie » 16 Jan 2006, 12:34
Setting Dimmer Curve on Diamond 4 console:
1) Select the fixtures you want to set the curve for.
2) Press the [DIM@] button.
3) Select "Curve" [Softkey F].
4) Choose the required curve.
LD Andy
Thank You
Postby LD Andy » 16 Jan 2006, 13:06
Thank you, I couldn't find it in the manual.
Andy
Olie
Site Admin
Postby Olie » 16 Jan 2006, 17:29
Neither could I. Will do something about that!
