I'm trying to get pallets recorded ( With image ) out of capture argo.
At the Titan V9 Features page it says that this is posibele
[img=http://www95.zippyshare.com/thumb/vUj7LLEx/file.html][/img]
In this picture you can see that i can record the "position"
When i klik on it, the window opens where i can select wat i want to record. Than ik klik record and nothing happens...
When i connect the universe to avolites, i'm unable to control the fixtures anymore in capture by klikking on the right mouse button
http://www.avolites.com/portals/0/9%20Position%20Palette%20Label.png
At this image is shown how it needs to look. this image is from the Titan V9 features page
There is no documentation that i can find for how to do this, or is it ?
I tried this in Hog 4 and i noticed that it works fine there
Capture Argo pallet recording problem
Exilonator
Re: Capture Argo pallet recording problem
FWIW I have never been able to get the record button in Capture to do anything in Titan and I have never seen anything suggesting this has ever been implemented in Titan, despite Capture (and Gregory in a similar topic recently) clearly suggesting it has.
I have tried both on the same machine and with separate consoles and playing with Capture options. In all instances Capture sees any assigned universes and I can control Capture without issue. Any connected consoles also appear in the 'projects' section of Capture. But regardless of Capture or Titan DMX settings with the universe and project connected and whatever option I select from the Capture record menu (ie. position/colour/cue and fixture/channel) nothing actually happens in Titan. Maybe Gregory can find the code that I couldn't...
Regarding not being able to control attributes locally in Capture when Titan is connected I would assume that is correct. Surely only one can have control?
CITP thumbnails as shown in your link do work however. Assuming you are connected and can control Capture fixtures from Titan, go to [Set Legend], select handle, [Picture] and click on the 'network' button (currently top-right most). This should load the current live view from Capture. Select this to apply as a picture legend. If this doesn't work check Capture CITP settings.
