I'm trying to do a "flashy" thing with a trackpod and as of now I can only do 8 steps in about a second.
Any suggestions?
1.1.1 DMX limitations on Chase Speeds
The following text explains why only some BPM rates are allowed.
Given that every step of a sequence MUST be output (otherwise some critical information may not get to a Fixture), the fastest Chase speed in BPM is determined by the DMX refresh rate.
The maximum theoretical DMX refresh rate is 44 times a second or 2640 times a minute. In practice this is not normally met, and on the Pearl a speed of 2400 can be achieved. In other words the maximum number of chase steps that can be output in one minute is 2400.
The next rate down is that on every other DMX cycle a new step is output, giving 1200 steps per minute. The next speed down from this is that on every third cycle a step is output, giving 800 steps per minute. This is how BPM’s of 2400, 1200, 800, 600 etc. are computed.
If a channel is to fade from 0% to 100% or 100% to 0% and every least significant bit (LSB) which is the smallest level change a channel can make then it will take just over 8 seconds for an 8 bit channel fade and over 27 seconds for a 16 bit channel. This is why many moving lights use smoothing to give smooth pan and tilt movement.
These limitations are inherent problems in DMX.
Users browsing this forum: Baidu [Spider] and 39 guests
