hi guys, i have made a shape with 6 moving lights, now i play the shape with 6 ml's . What if i wanna locate one fixture, from the 6 ml's to high light a person.... is it possible. wht i have noticed is that the light i locate keeps moving to the shape . is there a way to keep it in a locate position and then i could just move it according to my need.
thanks.
locate fixture
There does appear to be a workaround:
Program Mode.
Select the fixture(s)
Playback Shape
Select Circle
Set Size & Speed to zero.
This will stop any movement on the selected fixtures. You can now move it manually.
A more practical solution is on the feature request list.
/Edit: Pressing [clear] will restore the shape.
Program Mode.
Playback Shape
Select Circle
locate fixture
thats cool! thanks.... is there a faster way.
That does not work unless the information is in the programmer, ie. you would need to include the memory first. It would also remove all shapes, whereas the method above would allow colour shapes etc. to remain.
Not that it should work though! Is a bit strange that you can be running a Pan & Tilt combined shape, yet cancel it by running a circle set to 0.
