At the moment I am messing around with TouchOSC and given the possibilities of the program it would be handy if it could be integrated with the Titan software. The problem I encountered is that I can't find an OSC command list for avolites. I am working on a layout but couldn't code it.
Online I couldn't find a solid awnser if Avolites supports OSC at all.
http://hexler.net/software/touchosc
Greetings, Lars
TochOSC and Avolites
Re: TouchOSC and Avolites
Unfortunately OSC is not currently supported. It might not help you but MIDI Show Control is supported.
From the version 9.0 release notes:
There is now a factory trigger mapping for MIDI Show Control (MSC). The device ID can be set via the [MIDI] option in user settings. The following MSC commands are supported.The MSC device ID can be set in the users settings in the MIDI section. The console will always respond to the all call ID (7F).
- GO - Fire the specified Playback or Cue
- STOP - Pause the specified Playback or Cue
- RESUME - Un-Pause the specified Playback or Cue
- LOAD - Set the playback level to full.
- ALL OFF - Release all playbacks
- RESET - Same as ALL OFF
- GO OFF - Same as RESUME
