Titan Mobile, any benefit to connecting with USB3?
Judge
Postby Judge » 09 Jan 2016, 17:48
My laptop has USB 2 and 3 ports. Any advantage in using the 3? Will it benefit from the faster bus speed?
Also, if I connect to the network via ethernet port on laptop, I only have a 10/100 adapter at present. Is this fast enough or should I get a gigbit adapter? I generally only run up to four universes so not an awful lot of data flying around.
StijnS
Re: Titan Mobile, any benefit to connecting with USB3?
Postby StijnS » 11 Jan 2016, 10:30
Four universes of Art-Net can even run flawlessly on 10Mbit/sec, so don't worry your 100MBit adapter. For your info: a "normal" DMX line is about 250kBit/sec... :mrgreen:
I don't expect you will see any improvements with USB3, USB3 only provides a faster interface for endpoints that are designed for USB3. If the endpoint is built for USB2, it will fall back to the USB2 speeds.
Judge
Postby Judge » 11 Jan 2016, 12:17
Great, thanks very much.
Postby Gregory » 26 Jan 2016, 17:12
Just to note Avolites recommends using gigabit network for running TitanNet i.e. for multi-user or backup systems.
Users browsing this forum: No registered users and 92 guests
