Quartz connecting to wysiwyg By Wygalizer (don't work?)
euro1nl
Postby euro1nl » 04 Dec 2015, 10:48
I try to connect my quartz to wysiwyg
i have read the http://www.walterlutzu.it/wordpress/how-to-connect-avolite-titan-simulator-cast-wysiwyg/ and in the virtual console it work direct, nou i try i bij mij console i can ping the console i can see the luminex but i don't get any visual on wysiwyg R32
and ACDI 1.5 don't work in win10
what do o wrong ????
yyy898
Re: Quartz connecting to wysiwyg By Wygalizer (don't work?)
Postby yyy898 » 08 Dec 2015, 12:03
Is your firewall off ?
I have had this problem allot when my norton is turned on.
euro1nl
Postby euro1nl » 16 Dec 2015, 20:06
yyy898 wrote:Is your firewall off ?
Yes i have my firewall off
StijnS
Postby StijnS » 16 Dec 2015, 20:13
So, let me get things straight:
When you run Titan Simulator and WYSIWYG on the same computer, you can get it to work following the guide you link to in your first post?
And when you have a separate console and WYSIWYG on your computer, you cannot get it to work?
In that case: You don't need to have the loopback adapter when connecting a console to your computer. Just make sure the network adapter from both the console and the computer are in the same range. Eg 2.3.4.5 (subnetmask 255.0.0.0) on the console and 2.3.4.6 (subnetmask 255.0.0.0) on the computer.
euro1nl
Postby euro1nl » 03 Jan 2016, 19:20
thats right
when in run the software in my pc it work together
when i use my avo quartz is doesn't work, i use te arnet ip adresses
and the consol see te luminex
