What I want to know is after i have made a playback button, how can i then edit it. For example I set the gobos, I set the colours and a generated shape and record that to a button in the playbacks. Now I copy that button, because I want to be able to use most of the same settings again only in this button I want it to do exactly the same but lets say I want it to strobe, and maybe change the gobo. I just can't see an easy way to do this simple edit.
I am new to titan so only really just starting to get to grips with it, so if anyone can help and explain in easy steps that would be very much appreciated. thanks.
How do you edit a playback button??
Re: How do you edit a playback button??
Select the fixtures and make the change you need in the programmer. Then press record followed by your copied playback. You will be presented with the option to merge, either press this or press the playback button again. That's it, the playback should now contain your edit.
Thank you Olie.
