Titan mobile fader setup
gobucks1211
I am looking for a way to set up the 10 faders on our Titan mobile so that we can isolate the different colors of our LED fixtures. I am able to get them to show different colors, but each fader overrides the other. For instance, if I have red on a fader and blue on a different fader, I can show either red or blue but not both. I would like to be able to mix the colors to create purple for example. The hang up may be that the fixtures are LED and are the same fixtures for different colors. I am not very technical so my question is can I set up different colors on the faders using the same fixtures? If so, how is that done? Thanks.
Re: Titan mobile fader setup
Use record by channel. Record each playback with only the component required in the programmer at full (others at zero in the programmer won't work). Toggle each playback to mode 2 in [Edit Times]. Manually reset all components back to zero. You will now have separate proportional fader control of each component.
