I want my spots and washes to move and change collor on seperate times in the same cue, ex.
Spot move 3s
Spot change color 4s delay and 3s fade
Wash move 3s
Wash change color snap
Help please!!!!
Split que times
Re: Split que times
Assuming you're using Titan then you can set fade and delay times per attribute, per fixture.
View playback, view cue, select times from the context menu and then select the relevant cells to input values.
Re: Split que times
In the que?
Can you please explane a bit more??
Tnx for your time!
Tnx for your time!
