Cue recording strangness
Recently, without warning, when I record a new cue on a submaster - whatever is up on another sub gets recorded into my new cue. What gives? And why did this just start happening? Sometimes, another sub doen't even have to be up - just the last one used. This is espcially troublesome when I am trying to make a p/t or shape only cue.
re: strangeness
Oops - I forgot: Pearl 2004 with latest software.
Odd. I've never seen that.
Silly question, but I assume you have made certain that the information is not in the programmer for some reason?
Does this happen even after a reset?
AFAIK the only way you should be able to store/record information without it being in the programmer is via 'Record Stage'.
re:reset
Yea, re-sets. Clear memory, yada, yada. I have never seen this before. I record as usual - record memory. Merge memory.
re: strangeness
I've tried a wipe all and re-install of show. I normally run as "Record By Fixture", but this problem seems to go away if I record by channel.
re: Wipe all
I will try that when I get the chance. Today begins a busy weekend.
