Pearl encoder
mdudleyjames
Pearl encoder
After many years my analogue encoders on my old Pearl finally gave up the ghost. Avolites came to my rescue and sent me the new optical encoders (at a cost). All worked fine for a couple of hours then the tilt encoder would only count up to 100% which ever way you rotate the pot. Any ideas?
This would happen if either the clk or data wire from the encoder was bad connection. The most likely cause is a detached wire inside the sleeving on the encoder connections (try giving them a slight pull). Alternatively, it may be a bad connection at the connector (MASCON) end. Try pushing the cables into the pins with a small flat blade screwdriver.
mdudleyjames
