Hi, i wanted to write a macro to record keyframe shapes.
Turns out this doesn't work, i hit macro then record then the location to store to then i do everything to make a keyframe shape and when i finish i press macro again to stop recording.
While recording everything works fine, when done i run the macro and it opens the keyframe shape generator but doesn't select the fixtures in advance.
I made a video of it (http://nl.tinypic.com/r/244a0zs/8)
this is recorded while running v9.1 on a quartz but i had the same issue running v9.0
record keyframe shape macro
Re: record keyframe shape macro
As far as I can see this is a problem with full speed macros. If you set the macro to real time when recording it seems to work ok.
problem is indeed solved in real time speed.
It would be nice if this also works in full speed.
Maybe a feature for the next update
Users browsing this forum: No registered users and 101 guests
