BPM Fader
jb1996
BPM Fader
Postby jb1996 » 03 Aug 2015, 15:30
I got a problem,
I want to use BPM masters to control my effects and chases but when i use the master and tap the tempo the effect or chase dont step in tempo.
The whole effect is running under the tempo so that the whole effect is the tapped tempo.
I want that if you have a dimmer Spread effect and spread over 3 fixtures that run a fixture at a time as that blinks in tempo.
This was a bit difficult to explain ..
Can someone help me out?
Kind regards,
John
Re: BPM Fader
Postby Gregory » 03 Aug 2015, 18:31
Yes, I think I understand you. I believe this is to do with how the tap tempo value is interpreted, one calculates the time based on the individual step whereas the other uses the time for a complete cycle.
jb1996
Re: BPM Fader
Postby jb1996 » 24 Aug 2015, 19:52
Okey,
so can I do something about it?
Mars3110
Re: BPM Fader
Postby Mars3110 » 24 Sep 2015, 09:18
Hello, I have the same problem ! Any solution… ?
In Grand MA we can change the value of the speed of an effect or a chase (normal, divided per x or multiplied per y), but I can't find a similar option in Titan.
