I don't know if this a known bug, or if I'm doing someting strange. (titan v9)
Had a working show just fine. Needed to add 4 Clay Paky Mythos just before the show.
Did some patching to them, they worked just fine.
Programmed some Shape generator movements and dimmer shapes to the playbacks.
Also programmed some Key Frame color bumps and also movements inlcuding shutter to the playbacks.
Everything worked just fine.
Now did an restart of the console, and.....
All Key frame playbacks are empty! Also when you try to include them, nothing! When you Open/View the playback, empty!
The strange thing is that it only happend to Key Frame playbakcs, all the other Shape effects where fine.
I can repeat this error every time I make new Key Frames and do a restart.
The strange thing is that this only happend to added lighs, not the lights I programmed earlier.
So it has to do something with the fact that they have been added later or repatched.
Also I'm used to repatch fixtures from the view fixtures panel instead of the patch view panel.
Hope someone can relate, or knows what I'm doing wrong, thanks!
Key frames gone from playbacks after restart, known bug?
