External visualiser (realizzer)
Diar
Postby Diar » 24 Jul 2015, 16:01
Hi folks,
So I'm having a bit of trouble setting up my tiger touch with my new visualiser. I have Realizzer, and while its a great tool for working on the fly, i cant seem to get the touch to talk to it properly. I have gone through Avolites manuals for setting up networks and artnet connections, the Realizzer manual (not very in depth on the matter) and every you-tube video tutorial I can find on the matter. Unfortunately the Realizzer tutorials are in german which I do not speak which doesn't help my case much. I am useless at networks and getting anything network related running, however i am the best of a bad bunch to get the job done.
Has anybody used Realizzer with their touch and if so how did they get it running. The closest information I have found on setting it up is setting the visualiser with a touch simulator on the same laptop.
If anybody has a basic layman's terms walk through to get it running it would be a huge help.
Diar
Re: External visualiser (realizzer)
Postby Diar » 29 Jul 2015, 21:20
Ok so I figured it out and in case anybody else is an idiot like me I'll post the answer.
The realizzer runs with either containing it to a small number of machines with one serial code, or use on many machines with the use of a serial usb key. What I did not realise is that you need another usb dongle to work with straight dmx, or an artnet dongle to run with artnet.
All of the usb dongles needed. Although it is a very good visualiser so ill let that slide!
