Is it possible to install older version of the Titan, from V9 to V8?
I just run V7 full recovery and after completion l got message DONGLE NOT FOUND.
back to V8.1
totalworks4u
Re: back to V8.1
Yes, it is possible to install an older version of software by running a full recovery. However versions 7.0, 7.1 and 7.2 were all time limited so will not run if you attempt to install them now. If you wish to run version 7, you should run the recovery stick and then upgrade to v7.4/v7.5.
Users browsing this forum: No registered users and 77 guests
