Hello
Today I patched some 3channel LedPar with Generic RGB+vitual dimmer, everything worked fine as usual . but I tried to change the dimmer curve ( bound ,triangle etc...) no result , when I went back to linear , impossible to dim fixtures smoothly , impossible to light them off completly and when I flashed cues ( whith only dimmer on it) the leds stays at full
does those dimmer curves not working with virtual dimmer? a Bug?
PS , brand new Quartz (awesome Yeah) with R9 installed
thanks for your reply
virtual dimmer bug?
sunlightevent
Re: virtual dimmer bug?
Yes. Definitely looks like a bug to me. Curves are not applying correctly to virtual dimmers at a fixture level and, wherever set (even linear), there also seems to be a problem in response time - ie. flash = gets stuck on, fade down quickly = stuck part on, fade down very slowly = works correctly.
I will enter into the system.
In the meantime a possible workaround is to set the curve on the colour mix components rather than the virtual dimmer. ie. don't change the dimmer but set RGB to triangle or bounce etc.
sunlightevent
Great ... thanks I'll try it on R G and B channel
