"low on disk space"After installing V9.0
jesperspier
Postby jesperspier » 26 May 2015, 14:10
Hi Avo,
Afster Installing V9.0 by standard recovery the health check says that it's low on disk space...
"Drive C:\ has 1.3 GB (12.7%) free space
Do i need to do a full recovery or is the disk just too small?
I have a Tiger touch (first edition (T701))
Thanks for your help! :D
Re: "low on disk space"After installing V9.0
Postby niclights » 26 May 2015, 18:23
No harm in doing a full recovery (obviously backup showfiles first!)
Postby Gregory » 26 May 2015, 20:32
If you do a full recovery you will need a copy of the licence file to save you having to request a another one. You can get this from the email you were sent before or prior to running the recovery, copy the file from D:\TitanData\Tokens (this folder will be hidden but you can type the path into the address bar).
Legacylighting
Postby Legacylighting » 02 Oct 2016, 17:06
I'm having the same issue. New computer win 10. After installing v9.1 it keeps reading the D partition drive for Windows recovery. Meanwhile I have 650 gb + free on my C drive. I have Uninstalled and reinstalled multiple times and keeps reading the D drive. Not the C drive that's got more than enough. Any ideas?
Postby Gregory » 03 Oct 2016, 13:31
There was a bug that meant that HealthCheck would incorrectly check all drives when running PC Suite, this should be fixed in Titan v10.
