is it possible to use the executor buttons 11-17 as all the other executor buttons?
They have a preset of window settings (Open Attribute editor, etc). But I would like to use them for cues or chases. Is that possible?
Thanks,
Jürgen
Titan Mobile Executor Buttons
Re: Titan Mobile Executor Buttons
Yes.. I delete all of the stock macros and use the buttons for everything from specials to house lights to cue list for timer on my hazer. It's probably one of my favorite features on the mobile since it only has 10 playbacks.
Thanks for the quick reply! I tried deleting them, but in the Forum I now found how to do that.
Open (Window Control)
Delete
press Exe button 11~17
press same button again
Jürgen
Delete
Jürgen
So here is what I do...
If you go into the show library and then macros, there is a macro labeled 'Static Playbacks Page 0' and 'Static Playbacks Page 1'
If you copy the macro labeled 'Static Playbacks Page 1' to an open static playback button, press it, copy 'Static Playbacks Page 0' to the same button, you create a toggle that goes back and forth from the page with workspace windows and a page without.
I will typically record one or two dummy static playbacks to use as indicators as there isn't anything on screen to indicate what page I'm on (fix please!!).
You can also link one of these macros to a fader playback so when fired it switches to the page you need of static playbacks.. I hope Avo expands this functionality in the future!
That's a good idea, thanks!
I will test that this weekend...
If you are using the page macros you may want to lock them so that they appear on all pages. Press Playback Options softkey then the macro button to bring up the options.
Works great!
I did not know that I can change these static playback buttons and have more than one page
