dmx test
aymeric
dmx test
Postby aymeric » 12 May 2015, 08:17
I currently use a titan pearl expert V9 .
Is it possible to bypass the patch? Is it possible to turn on a dimmer by its DMX address. thank you
Quidam
Re: dmx test
Postby Quidam » 13 May 2015, 18:56
It kinda is, using the 'find fixture' option in patch mode.
Press patch>dimmer>options>activate 'Find fixture', press exit.
Then you can use wheels to select dmx line and dmx channel. Selected channel will be set @ 255.
(NB : Using this option while patching fixtures will locate the selected fixture)
This is of course, however, temporary (selecting another channel or exiting patch mode will set your channel back to 0) and, afaik, you cannot chose a custom value for this (i.e. '127', or '50%').
Out of this, no, it is not possible to light a fixture out of the blue without patching.
You cannot, for example, use your avo to test channels 2, 6 and 9 by sending mixed and simultaneous dmx values without patching.
You can use an expensive DMX tester for that - or just patch the damned channels :-)
Re: dmx test
Postby niclights » 14 May 2015, 01:09
I think you should be able to do this via Usb Expert Console. Select the DMX panel and have a look at the options under the DMX tab.
aymeric
Re: dmx test
Postby aymeric » 14 May 2015, 11:16
great!
thank you Quidam.
The option " find fixture" is exactly what I want.
Users browsing this forum: No registered users and 106 guests
