titan ver 9 as well has this problem, program a shape for eg a circle and change the mode to 2 this works fine. when the cue is link copied to another playback the edit button will show the mode as 2 but the shape will bump in. to alter this have to press mode switch again and bring it back to mode 2 then the playback works as expected.
This is really annoying when one has the cues common on every page and needs them to be linked and the shapes bump in.
Lloyd
mode not staying on link copied playbacks
Re: mode not staying on link copied playbacks
I believe this is by design. It is intentional that the link is only for the control values in the playback, not the timings. No doubt there are arguments for and against this and perhaps there could be an option in the future to allow both. Note that normally you would use the playback option settings to control shapes by fader rather than mode 2.
If you want the same playback to appear on several pages you can use the Handle Paging setting in Playback Options to do this. Transparent will make it appear on all pages where there isn't something else already recorded, Locked will appear on all pages even if something else was recorded there. This only works however if you want the playback to appear on the same fader on each page, it won't work if you want to use different faders.
