Shape Generator Lock-up (Pearl 2000 AND 2004)
jaycoolyea
Postby jaycoolyea » 21 Oct 2005, 17:03
at my church we are currently running 2 avolites consoles (one in main worship center and one in the youth building). I have tried this on both consoles and got the same result. All of the shapes that have actual shapes in their name (circle, square, diamond), and the P/T swing and saw all work perfectly. But when I select my moving head fixtures and try to select a shape involving something like dimmer, pulse, or rainbow, I see the shape on stage, but the console locks up. This happens on both 2000 and 2004 consoles.
Anyone know how to solve this problem?
Thanks,
James Poole
jpoole31@earthlink.net
Postby niclights » 21 Oct 2005, 18:48
That's strange. I can only think it is a personality error.
Pls confirm software versions. Are they the same fixtures and if so what are they?
I use 'dimmer' and 'rainbow' shapes on all 2004 software builds without problem.
jaycoolyea
Postby jaycoolyea » 21 Oct 2005, 22:26
it did the same thing on all of the following fixtures:
Pearl 2004 Console:
-martin mac 600
-martin mac 2000 profile
-martin roboscan 1220
-elation powerspot 250
Pearl 2000 Console:
high end x.spot
high end studio color HX
martin roboscan 918
i tried it on each fixture seperately, and got the same result: a lockup.
Postby niclights » 22 Oct 2005, 03:39
Even stranger. Clearly not fixture related.
How about the software versions? (System menu)
Are there any bus errors?
Unless there is something obvious I am missing, then I am inclined to think that a showfile and/or shapefile has become corrupt. I had been quite sceptical about corrupt showfiles until recently when I saw an example where some fixtures would not locate, even though they otherwise seemed to work correctly. After much head-scratching I noticed that all the attribute names had disappeared from above the wheels. Somehow the personality had become corrupt.
You could try loading a new shapefile (SHAPE.DAT)
Can you repeat this from a wipeall/fresh patch?
/Edit. Of course since you have different fixtures in the two venues I am guessing this is not a shared file either. The plot thickens! Perhaps there is something wrong with the latest shapefile?
Olie
Site Admin
Postby Olie » 24 Oct 2005, 09:38
This is a fixture personality problem that we are well aware of. It is possible that if you download the latest personalities for those fixtures then the problem will be solved. However I will get our personality guy to look at the fixtures listed on this thread.
Users browsing this forum: Baidu [Spider] and 31 guests
