Problems with Mac TW1 personality
kox
Postby kox » 05 Apr 2015, 13:55
Anyone else experiencing problems with the 20 channel EXT personality for Mac TW1 on Titan Mobile ?
It's not made up right...
Use the 20 channel 16bit instead as its working perfect :-)
Re: Problems with Mac TW1 personality
Postby niclights » 05 Apr 2015, 14:14
The mode names might be slightly misleading. The 'Ext Dim' modes have a pending dimmer in place of the electronic dimmer when using the external dimmer option. If you are using models with internal dimmer then you need the 14 DMX, 16bit or 20 DMX, 16bit. If you are using an external dimmer then you need 14 DMX, Ext Dim or 20 DMX, Ext. Dim with a separate dimmer patched over the top.
kox
Postby kox » 05 Apr 2015, 14:19
Make sense when you say it.
But in display on lamp you choose between 16bt or 16ex when using 80v internal dimmer
Postby niclights » 05 Apr 2015, 14:29
Sure. I'm reluctant to change the mode names as it will break the update personality function.
kox
Postby kox » 05 Apr 2015, 14:34
All Good :-)
