v9 Colour palette bug
Clayton
Postby Clayton » 24 Mar 2015, 16:48
Hi, there -
I'm seeing a bug in the way the v9 Colour palette behaves. This is Titan PC v9 with Titan Mobile.
    1. Create a color palette for a given fixture A. Clear.
    2. Select a different fixture type. Notice the color palette from step 1 is grayed out and un-selectable. OK.
    3. Create a color for the second fixture type and quick-merge into the color palette created in step 1.
    4. Clear.
    5. Select fixture type B. The color palette button is STILL grayed out, even though you just merged into it.
    6. Restart Titan.
    7. Select fixture type B again. After the reboot, the color palette button is no longer grayed out and behaves as expected.
Can you confirm the bug?
Thanks!
Re: v9 Colour palette bug
Postby niclights » 24 Mar 2015, 17:18
Confirmed. Actually it should highlight from the point of merging. Thank you for providing a clear and detailed report. I will enter into the system. Note to anyone else looking at this you need to ensure the original palette is shared or normal (ie. not global).
